This is a very simple request, and it relates almost exclusively to CAM toolpath processing/generation. I want the CAM aspect to utilize more of my processing power. I have eight cores, but the CAM kernal is only running 13% load while everything else (and it's not much while I'm trying out adaptive clearing toolpaths) runs like nothing is going on at all.
I'd really like the ability to ramp up the system power I've got that Fusion uses, if not only for toolpaths, then for everything. 75% CPU load still leaves me with two cores, but I also suspect that at that level it'd generate even heavy duty paths rather quickly. Otherwise things are great, and it beats the pants off of waiting almost an hour for Mastercam to do the "same" calculations.
