Show only
Search instead for
Yes, I used this a lot in other applications. Also, somewhat related, the ability to extract curves from the intersection of two objects. This would be great to have as a part of 3D sketching.
Hi cekuhnen, are you talking about conforming a curve/sketch to a surface or having a projection that results in a curve on surface similar to what Alias does?
Projecting a 2D sketch onto a surface resulting in a 3D sketch and creating 3D sketches from intersections of solids or surfaces are work flows I rely on heavily in other CAD. This enters into the question of 3D sketches, 3D splines and by extension to absolute cartesian coordinates. All of these capabilities are useful.
I believe that Maya has similar NURBS functionality. You draw a 2D spline in 3D space and then project that 2D spine onto a NURBS surface. I assume we would want to create the curve on a sketch plane offset from the body, and then project that sketch onto the body. I would like to have functionality that for both T-spline and solid geometry.
Hello all, I'm seeing two requests here. One is the ability to snap a T-Spline surface down to another surface. You can do this today using the object snap option that appears in several of the scuplt tools (face, subdivide, edit form, insert edge). There is also a Pull command that will snap a T-Spline surface down to a target surface. Target surfaces can be Solid or Mesh bodies.
The second request is the ability to project a curve on to a surface, that is not available yet. It has been discussed but I don't know at this time when it would appear in the software. If this is important to you be sure to give it Kudos.
To project a profile onto a surface is a pretty important tool. I am surprised it is not given a lot of importance. You cannot to this only through simple solid modeling.
Sometimes you project a curve onto a surface so you can extrude something along that curve and not only trim the surface with the projected curve.
I agree about the importance of projecting a curve onto a surface/ solid. In a related issue, while Fusion does have draft analysis tools, there doesn't appear to be a way to create a parting line curve on the surface of an object by using them. I was hopeful that when 3D sketching was enabled this would be a possibility- but maybe there is a workflow I am missing?
Closing this as we have project to surface. Looking to see if the community needs improvements or wants additional capability to draw directly on surfaces. We should track these as new separate ideas.
Hi guys, I don't know if this is any relevant, but what I want to do is to map sketches (a patern for instance) on an object and then pipe it or cut it out or any thing of this sort.
Wouldn't be great if we had a tool similar to "Conform Rig" in Alias something similar I mean, to map sketches or objects on other objects. I am preety sure you can imagine the power such a tool can add to the modeling and conceptualizing process. I am attching a simple example of what I have in mind just to make sure my idea is delevered properly.
doing this manually is possible in this example, but not what a designer is looking for. accurecy and control.
"Does actually ProE/UG or SW have those tools? I dont know because I do not use them or have access to them."
I have no idea.
"However the bottle could be build by the way with a dense ts model / mesh that is snapped onto a BREP master surface."
As per this, I can't say that it sounds Greek to me since I am Greek. But what's with the abbreviations? explain if you please, and I will be grateful if you link me to a tutorial or something...
