I just noticed that Fusion does not store the rotation factor when moving rotating etc an object.
This is a major short comming of the design timeline idea and adding features.
What purpose does the move feature have when after I did a command I do not know what I did.
With an extrude command it always tells you how far you extruded etc.
So the move command has to have also store the move and rotate values!!!
Otherwise I have to write down on paper what I did.
