Show only
Search instead for
For the select a face and drag... Would you find to much an interruption to your flow if:
you select a face, it highlights an a small glyph appeared on the face. If you click the glyph and drag then the edit face command (i.e. Press pull for solids or edit rom for tsplines) automatically started?
