Hi
this also is a topic we already discussed months ago and i can't really believe that nothing happened so far.
By default Fusion360s (and other 360 products) world coordinate system is aligned so the Y-axis is UP. I understand that this is the default in some regions of the world or maybe some businesses but also it is true that:
- all of the 3D printers i know
- all of europe from schools up to university, architects, engineers
- some other Autodesk products (at least AutoCAD Mac 2014)
- loads of other 3D-Software (like Sketchup, OpenSCAD
- even the english speaking Wikipedia shows "Z-up" as their example for a cartesian coordinate system http://en.wikipedia.org/wiki/Cartesian_coordinate_system
...they all use "Z up" as their default.
I accept that you still could discuss what should be default but it's a desaster that all the 360 products are still not able to simply switch orientation in a way that works throughout the system and doesn't need a dirty hack that crashes every now and then on different actions.
My hack:
1. rotate objects so they fit the "right" orientation.
2. rotate view to you look straight to the top of your model
3. right click the house symbol next to the view cube and "set current view as... > top"
4. rotate to a view that you would use as a home position
5. right click the house symbol again and "set current view as home...-> fit to view"
This basically works for STL exports which means the STL files i export now have the correct orientation to work with the tools in my 3d printing toolchain (and no, the autodesk print utility is not within this toolchain).
But: What you then get is rotated thumbs in the dashboard because your view settings don't get respected here (even though the named views in Fusion work as they should). Also Fusion360 is broken when you "save copy as" a component - the new file completely reseets your settings again and Y axis is up again.
I wish there could be a simple default setting for this and a setting on a per file base that lets me override the default setting for single files without having to take 5 steps and refixing everything after a copy-save action.
