Well, i'm not keen on the name DPRP but hey - it sounds sexy, doesn't it? 🙂
We talked about that in todays hangout. What Fusion360 is missing is a possibility to easily position a feature or object relative to other features, objects, edges or points. You can always position things relative to there actual position but not relative to other stuff.
It would be great to have a possibility to do so. One possible solution could be a dynamic positioning system where you choose the object/edge/point that you want to position relative to and then enter the values. Maybe another step is needed if you probably want to find a point relatively to two edges.
I hope this is also comprehensible for people not having joined the hangout if not i could still try to go more into a detail but basically i think we need some tools to do more exact relative positioning.
Frank
