My suggestion would be to implement some sort of an absolute coordinate system.
The key points would be:
1. Having a X:0 Y:0 Z:0 point
2. Having an option to use the coordinate system when transforming/moving an object/feature/point/sketch
3. Having an ability to measure any point in space to retrieve its coordinates
I attached an example of how it looks like in Autodesk 3dsmax.
Cheers!
This is really important when it comes to CAM, because I need to precisely position my model relative to my stock, the origin of which defaults to the center of the grid in Fusion 360. The workaround right now is to create a sketch, which allows me to snap to grid coordinates that happen to be where I need the center of my model, then extrude the sketch, then do a point-to-point move where I move the center point of my model to the corner of the sketch that snapped to the point I needed. It works, but it would be nicer if I could just select my model and type in 0.5, 0.5, 0 for the xyz values. There clearly is a coordinate system, but having direct access to it would help me a lot.
In our move command you can now transform using X, Y and Z. Does this meet the needs of your idea?
Mike Prom
I've been wondering the same thing about absolute coordinates. I think what he is asking about is the ability to set or have a preset origin point, and that you can view and change the x, y, and z distances of any object from this point, and that those values defined the position of the object in the 3d space. If I'm not being clear enough, tinkercad's ruler tool is a perfect example of this. So far, I can't seem to find an equivalent tool or setting in fusion, and I think it would really benefit from it, to the point of it being almost essential, at least from my perspective as someone who came from using tinkercad first.
I agree that there should be an absolute movement option.
For example, how can I move this box from it's current location to (absolute) X6, Y3, Z12 using the available move options?
Create a sketch with a point located (dimensioned) at the desired absolute coordinate and align the part to it and take a snapshot.
Then you can delete the sketch, or add more points for more parts to be positioned.
If you're using components you could create a joint origin and use a joint to move the component. Done like this you can go back and edit the join origin and the position of the box will update.
Mark
Mark Hughes
Owner, Hughes Tooling
@promm There should be a simple relative/absolute toggle, just like a cnc mill would have.
TrippyLighting Align seems to rotate the component to the plane the point was created on on.
@HughesTooling Not quite following you, where would I position the joint? it seems like the joint origin would need to be twice the distance in every axis to make the part act like it's being moved from 0,0,0
Relative moves can be handy, but my mills are in absolute 99.9% of the time.
Make a joint origin and select the document origin as the base point. My picture above shows an absolute distance from the document origin.
Mark
Edit sample file attached, try selecting the joint origin in the timeline and editing it's position. The box will go back to it's original position while editing but when you click OK it will go to the new position.
Mark Hughes
Thanks for the file, I see what your saying now. My origin bulb was off and I couldn't snap from 0,0,0 for the joint origin.
This method still rotates the component to match the new joint origin's plane, unlike a move command, which will move the part without changing the orientation.
Have you got a screen grab or sample file. If you activate a component you can create another joint origin in the component and with the use of Reorient you have a lot of flexibility to work with. I know this will take a bit longer to setup but at least you can go back and have full control over repositioning if you need to.
Mark
Mark Hughes
Take the simple box component you created, rotate it in any axis using the move command, and then try moving it with the joint origin method.
The box component will move to the correct location, but it rotates the box component so that the joint buttons align planar.
I don't have a screen recorder on this computer, but I will load one if needed.
If you create a joint origin in the component, select the base point then tick Reorient then pick the Z and X axis of the document origin it will not rotate when you add a joint.
Mark
Mark Hughes
