Discussion Groups
Fusion 360 Beta
Active Contributor
Accepted Solution
Primo Problema
166 Views, 5 Replies
12-19-2013 08:04 AM
OK ... it's all a bit 'weird.
I must say that I find it much more powerful and I like that :smileywink:
All options that are able to prove I loved them.
But I have a problem with an item created in sculpt that is present in the file (Prova_1 inside ProvaFusion) but I do not find myself in the Browser.
Everything I try to do on this object becomes a mess
Fabio
Please use plain text.
Active Contributor
Re: Primo Problema
12-19-2013 08:09 AM in reply to: filiberti.design
MacPro 2008
2 x 2,8 GHz Quad Core Ibtel Xeon
8 GB 800 MHz Ram
ATI Radeon HD 2600 XT 256 MB (a bit 'poor but ...)
OSX 10.9.1
Product Support
AndrewSears
Re: Primo Problema
12-19-2013 12:00 PM in reply to: filiberti.design
Fabio,
Can you invite me to view the file?
Send the invite to andrew.sears@autodesk.com
If you don't want to invite can you attach it to this thread?
Andy
Board Manager
Phil.E
Re: Primo Problema
12-20-2013 08:06 AM in reply to: AndrewSears
I think the issue here is that sometimes open sheet bodies created in the Create Form workflow are not represented in the browser once you return to parametrics. Some steps to reproduce will help. I can't repro it right now but I've seen it before.
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Autodesk, Inc.
Product Support
AndrewSears
Re: Primo Problema
12-20-2013 10:53 AM in reply to: Phil.E
I can reproduce this problem.  The cause seems to come from a combinition of deleteing then use undo while the timeline is moved towards the beginning.
Thanks for reporting this!
Andy
Active Contributor
Re: Primo Problema
12-20-2013 10:56 AM in reply to: AndrewSears
Ok
Thanks!
Fabio
Inviato da iPhone
