Freewheel (Read Only)
Sharenow - where is it?
8 REPLIES 8
Message 1 of 9
479 Views, 8 Replies
I installed sharenow for Revit, but when I open Revit, I see nothing new - no external tools no toolbars, etc.
As there is no documentation with the install I have no idea where to start...
i am running Revit 2008 (20070810_1700) in Vista x64.
PARTIAL REVIT.INI FILE:
[ExternalCommands]
ECCount=7
ECName1= HelloWorld2
ECClassName1= HelloWorld2.HelloWorld2
ECAssembly1= C:\Users\deagle\Documents\Visual Studio 2008\Projects\HelloWorld2\HelloWorld2\bin\Debug\HelloWorld2.dll
ECName2="Acquire from Google Earth"
ECClassName2=GEAcquirement.Acquirement
ECAssembly2="C:\Program Files (x86)\Autodesk\Revit 2008 Globe Link\Revit2008GlobeLink.dll"
ECName3="Publish to Google Earth"
ECClassName3=GEPublish.Publish
ECAssembly3="C:\Program Files (x86)\Autodesk\Revit 2008 Globe Link\Revit2008GlobeLink.dll"
ECName4="Import Google Earth File (KML/KMZ)"
ECClassName4=GEImport.Import
ECAssembly4="C:\Program Files (x86)\Autodesk\Revit 2008 Globe Link\Revit2008GlobeLink.dll"
ECName5="Export Google Earth File (KML/KMZ)"
ECClassName5=GEExport.Export
ECAssembly5="C:\Program Files (x86)\Autodesk\Revit 2008 Globe Link\Revit2008GlobeLink.dll"
ECName6="Batch Print"
ECClassName6=Revit.PrintHarness.PrintHarnessAPI
ECAssembly6="C:\Program Files (x86)\Autodesk\Batch Print for Revit 2008\BatchPrint.dll"
ECName7="Worksharing Monitor"
ECClassName7=WorkSharingCommand.WorkSharingCommand
ECAssembly7="C:\Program Files (x86)\Autodesk\Worksharing Monitor for Revit 2008\WorkSharingCommand.dll"
[ExternalApplications]
EACount=1
EAClassName1=Autodesk.Freewheel.RevitAddin.ShareNowApp
EAAssembly1=C:\Program Files (x86)\Revit Architecture 2008\Program\\RevitShareNow.dll
EAName2="Worksharing Monitor Lib for Revit 2008"
EAClassName2=WorkSharingLib.ExternalApplication
EAAssembly2="C:\Program Files (x86)\Autodesk\Worksharing Monitor for Revit 2008\WorkSharingLib.dll"
8 REPLIES 8
Message 2 of 9
To get started:
1.. You download the installer ZIP file.
2.. You unzip it.
3.. You pick the MSI installer that you want: 32-bit AutoCAD 2008, 64-bit
AutoCAD 2008, Inventor 2008, Inventor LT, or Revit 2008. You execute the
desired installer.
4.. The next time you fire up your application, ShareNow is available.
This invokes new functionality.
Autodesk Revit: Icons for sharing the current view of the building
information model and sharing all views of the building information model
appear.
There's a YouTube video you can view:
http://www.youtube.com/watch?v=YWr5OmYQpiM
wrote in message news:5853366@discussion.autodesk.com...
start...
[ExternalCommands]
ECCount=7
EACount=1
Message 3 of 9
As I mentioned above, I already installed ShareNow.
It does not show up anywhere.
Message 4 of 9
Do you have more than one version of Revit on your computer? Our installer
is not that smart. It adds ShareNow to the first Revit it finds, which might
not be the right one.
wrote in message news:5853947@discussion.autodesk.com...
Message 5 of 9
No - only one version.
Is your installer able to find it in the C:\Program Files (x86) folder?
Message 6 of 9
I have not tried this. I will ask the development team to try it. The
empirical evidence suggests "No."
wrote in message news:5854672@discussion.autodesk.com...
Message 7 of 9
you need EACount=2
EACount=2
EACl assName1=Autodesk.Freewheel.RevitAddin.ShareNowApp
EAAssembly2="C:\Pro gram Files (x86)\Autodesk\Worksharing Monitor for Revit 2008\WorkSharingLib.dll"
Message 8 of 9
We have determined that this is a problem on a 64-bit machine. We plan to
address it in our next release.
Message 9 of 9
Have you find a solution to start batch in vista x64?
