Freewheel
Active Member
giordandue
Message 1 of 2 (1,259 Views)
Problem in rendering
1259 Views, 1 Replies
10-17-2011 09:26 AM
after have worked by ADR12 on a pdf drawing (derived from dwg), I would save it (as dwfx file) in Freewheel.
Nevertheless, only my over-imposed corrections appear on the web page (http://freewheel.labs.autodesk.com/......), while the original drawing is missed. Any suggestion?
Incidentally, I use a pdf file because I met problems in opening directly dwg in ADR by DwgTrueView (see discussion opened with ADR group).. How many problems!
Thank you
Board Manager
scott.sheppard
Message 2 of 2 (1,236 Views)
Re: Problem in rendering
11-20-2011 08:39 AM in reply to: giordandue
If you export a DWF and mark that up with ADR, you should be able to load the DWF into Freewheel. You should resolve the publishing issue so it lets you skip the PDF part.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
You are not logged in.
Announcements
Need installation help?
Ask the Community
