I assume you are trying to install the 3D/2D ShareNow utility. Project
Freewheel itself does not need any install. You just use our server. Some
people have had the installer not recognize their AutoCAD if the installer
does not find a registry key it expects. This key is put there by the
AutoCAD installer. When these users have installed AutoCAD through some
other process, e.g. a bundled installer, the key is not present. We may make
the ShareNow installer more robust in the future.
wrote in message news:5710300@discussion.autodesk.com...
Hi all,
New member here with a query similar to the last one, regarding installing
FreeWheel.
I am encountering a similar message when trying to install. I use AutoCad
2007..
Thanks for any help or suggestions,
Nigel
