Freewheel (Read Only)
Digital Rights Error
3 REPLIES 3
1167 Views, 3 Replies
I have been successfully using Freewheel embedded in a blog for some time, but I am now getting an error when I publish and upload new drawings - "the requested DWF file has been protected with digital rights management. At this time Freewheel does not support DRM protected DWF files."
I do not understand where DRM is set in the Inventor 2009 application I used to publish these files. Please let me know what I might be doing wrong.
I have attached an assembly drawing that appears to be protected in this way.
Keith
3 REPLIES 3
Digital Rights Management properties are set when a DWF is published that
does not allow measurement, markup, or printing. I believe your Inventor is
publishing a DWF that cannot be measured. As part of your publishing
properties, if you have disable measurement checked, you will want to
uncheck that.
wrote in message news:6328640@discussion.autodesk.com...
way.
Keith
Nope, that wasn't it. But I did change the published format to dwfx and that displayed fine.
Maybe something has changed on the Freewheel service?
Now that I would know about. I am one of the guys who updates the Freewheel
server. Since the XPS format does not allow for digital rights management,
whatever setting you have in Inventor is ignored when you publish a DWFx and
you just get a plain old DWFx file (contents are XPS).
wrote in message news:6329169@discussion.autodesk.com...
