Freewheel (Read Only)
3D DWF pipeline hiccup
3 REPLIES 3
Toggled
272 Views, 3 Replies
Afternoon all.
I've been looking into web based 3D for a while now and freewheel is looking like the way to go.
The main stumbling block i have at the moment is that i capture a DWF from Maya and it open up in the DWF viewer all nice and 3D. However when i embed it into a web page i'm not allowed to rotate it in 3D, it'll spin on it's facing axis, pan and zoom but no real rotation. I tested by embedding the suspension example in the same site and that worked fine.
So i'm wondering if there's a step i'm missing along the way to make the DWF ready for freewheel??
Cheers in advance.
3 REPLIES 3
in reply to: Toggled
Please try it on http://freewheel.labs.autodesk.com and let me know if you
have the same problem.
wrote in message news:5736664@discussion.autodesk.com...
Afternoon all.
Cheers in advance.
How are you embedding? Are you setting the camera with your code or are you
using the Freewheel tools?
Ben
"Toggled" wrote in message news:5736664@discussion.autodesk.com...
Afternoon all.
Cheers in advance.
Toggled
Thanks for the quick reply people.
Couldn't get the freewheel/labs link to load this morning, i'll try again later.
I was just embedding by editing the example http://freewheel.autodesk.com/dwf.aspx?path=http://freewheel.autodesk.com/sample/Hotel5.dwf&sec=1
and changing the path. Should i be adding in some of the string/floats if i want it 3D?
Cheers again. Message was edited by: Toggled
