Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Unable to Install: The procedure entry point...
4 REPLIES 4
reshef.elisha
1392 Views, 4 Replies
I'm trying to install Flow Design. I'm using Autodesk Education, if this changes anything. This happens every time I try to install. I've tried every option (Download now, install now, browser download), and they all give me the exact same message. I've deleted C:\Autodesk and retried, still nothing. Does anyone know what's going on? I attached the error message.
This only happens in Flow Design, and I'm using windows 8.1, by the way.
Thanks in advance.
Tags (1)
4 REPLIES 4
Royce_adsk
in reply to: reshef.elisha
Hello Reshef,
This is not typically a unique problem related to Autodesk installation, but more of a windows issue.
There are many resources that can help online from a search.
Typically, the way I get around this issue is creating a new user account on the computer just to install the software.
Best regards,
Royce.Abel
Technical Support Manager
reshef.elisha
in reply to: Royce_adsk
Well the search you posted seems to say that it's due to incompatible system requirements, but the System Requirements for Flow Design say that windows 8 x64 (What I have). Since the library that causes trouble is one that is downloaded during the setup, I assumed that it had to do with only Autodesk.
I tried creating a new user account, but got the same problem.
Royce_adsk
This could be associated with Windows 8.1.   The QA team only tested and confirmed with Windows 8.0.
Royce.Abel
ispiriev
I am currently getting the same error on windows 8.0, any suggestions? 🙂 I meet all system requirements and am also using educational version. I tried logging with different user, but the error persists.
