Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Surface Pressure
1 REPLY 1
1117 Views, 1 Reply
Surface Pressure
I am using Flow Design for Revit.
I would like to check the surface pressure, but even if I follow the help guidance (http://help.autodesk.com/view/ADSKFD/ENU/?guid=GUID-8F550BF7-55F6-4189-ABFC-A1630687456B), I cannot see the numerical values on the surface with my model. (the model has been downloaded from BPS certificate website.) And the legend is also showing "0" from min to max.
Can anyone please let me know how to fix this? : )
So Hyun
1 REPLY 1
_ew
Default Revit units for pressure are set to ksi for the imperial template and MPa for the metric template.
This is probably why you don't see any numerical values except "0".
If you change pressure units to Pa, you should see correct numerical results for the legend and plots. To do this, go to the "Manage" Ribbon tab, then choose "Project Units", then  choose discipline structure and change the units for stress to Pa.
Emmanuel Weyermann
Emmanuel Weyermann
Sr Software Architect
Link Name | Link Name | Link Name | Link Name
