Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Opening Models
7 REPLIES 7
Message 1 of 8
jhendrix
1171 Views, 7 Replies
Opening Models
Running on Windows7.
Have tried to open .obj/.stl files and keeps opening the sphere everytime. In the file types I  don't see .wire option?
7 REPLIES 7
Message 2 of 8
Royce_adsk
in reply to: jhendrix
Would it be possible for you to send me the models?  You can private message them to me if they are small enough.
Royce.Abel
Technical Support Manager
Message 3 of 8
jhendrix
Managed to import model. Had to select 'tessellate' in the save dialogue box for .obj files in Alias!
Still disappointed that I don't see the .wire format -qv attached screenshot?!!
Message 4 of 8
ryan.arnaudin
Did you uncheck the Design Link option during installation? Leaving this checked will enable many additional file formats to be read by Flow Design.
Message 5 of 8
jhendrix
It was unchecked -all is good.
Many thanks.
Message 6 of 8
ryan.arnaudin
It's a confusing name, for sure.
Message 7 of 8
dpottier
in reply to: Royce_adsk
I am having the same "ball" issues with every file format from Inventor 2015 - extruded ipt, aim, dwg and with any jpg images as well.
Message 8 of 8
ntzmc_strife
in reply to: dpottier
Having the same issues as well. Tried using Solid Works 2014 with .sldprt and Autodesk Inventor 2013 with .ipt.
