Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Model Units Issue
2 REPLIES 2
Jaimevalente
572 Views, 2 Replies
Model Units Issue
Hi
          I imported a palm tree model in .sat, but I wasn´t sure about the drag force, so I notice that the dimensions of the wind tunnel wasn't congruent whith the size of the model. I put the same units of the model in the flow design program.
      Thanks for your help.
2 REPLIES 2
hartogj
in reply to: Jaimevalente
Interesting model.
SAT (ACIS) neutral formats can be scaled unexpectedly depending on the file history, ie. where it was created and how it was written out.
What is the intended height of the tree? You can change the "model dimensions" menu to rescale the model. It looks like "Feet" or "Inches" may be the right model dimension in this case.
Jon
Jon den Hartog
Product Manager
Jaimevalente
in reply to: hartogj
Thank you for your response
Apparently the model is in inches, but I´m not still sure about the drag force. By the way, this model pretends to simulate the wind force of an artificial palm tree on a telecom monopole.  palmera 4.png
