Morning
yesterday i did a flow simulation of a simple flat surface that have an angle of 30° to the orizontal plane. The output program gave me the pressure distribution but i don't find the way to obtain the net force direction and its point of application.
How i can find this information in Flow design?
Solved by Royce_adsk. Go to Solution.
Hi
Thanks for your reply. First sorry for my english. I understand that Flow Design is a wind tunnel simulation and its principal date are pressure and velocity. Using Drag plot i can have the magnitude of the total forze, but i need the centre of the forze. Whitout this information i can't calculate the fix point of the simulated structure. In the specific case i would like simulate an photovoltaic structure, and if i don't know the exactally coordinates of the center of the forze i can't calculate the fix point. If with this program i can't obtain what i need you can suggest me some other program.
Regard
Francesco
I would suggest that you add center of force needs to the idea station.
Autodesk Simulation CFD can determine those outputs for you.
Best regards,
A complete selection of top-tier leak-proof integrated balancingmanufactured to stand the test of time and perfected through design innovations to achieve and maintain continuous optimum flow rates, superior debris resistance and reduced dimensional sensitivity with minimal easily-serviced maintenance.
Can you please tell me how would i get rid of encounter in the flow and provides solutions for working around them how ?
