I have tried import dwg file to Flow Design then keeps opening sphere everytime.
I work on Windows 7 (64 bit)
What should I do??
Attached DWG MODEL.
Solved by hartogj. Go to Solution.
Solved by Royce_adsk. Go to Solution.
I used Inventor Fusion to read in the DWG file and converted it to a STEP file format and that allowed it to work.
Thanks for your help but I don't use Inventor Fusion. Is possible to make the conversion in another program ( program used in civil engineering) or
Hi
Thanks for letting us know you are seeing this.
The development team has tested this and observed similar behavior on some files generated in AutoCAD 2010 and later. The issue has been logged.
For now, as a workaround I would recommend outputting an STL straight from AutoCAD, ie. File>Export>Other Formats>Lithography (STL). There are lots of ways you could do this but this is likely the fastest.
Jon
Hi
I had a similar problem so i Export my file to FBX format and it worked.
Try it out.
i am using inventor for 3d modelling and when iam trying to open .ipt file in flow design a sphere shows up can anyone solve my problem...?
