• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    File Attachments
    Member
    Problem Macro Copy Rotate
    143 Views, 3 Replies
    04-24-2009 02:56 AM
    Hi, i've a problem with using the macro menu.
    I want take an object and its insert point. in the same point I should rotate the object without using the rotate command.
    I want to create a command where i can copy, insert this, eand rotate an object.
    i've wrote in the MACRO MENU:
    ^C^C_copy;\;_int;\;_rotate;
    The
    problem is that when i take the object, without define its insert
    point, it's copied in to the screen, and a can rotate only the object
    original, not the copy.
    I'm sorry for my english...
    Thanks..
    Marco
    Please use plain text.
    Distinguished Contributor
    Re: Problem Macro Copy Rotate
    04-28-2009 04:30 AM in reply to: Maark
    type MOCORO
    Member
    04-30-2009 07:50 AM in reply to: Maark
    is possible an automation for Mocor..
    Initializing...
    _MOCORO
    Selezionare oggetti: trovato(i) 1
    Base point:
    [Move/Copy/Rotate/Scale/Base/Undo]<eXit>: C
    Second point of displacement/Undo/<eXit>:
    Second point of displacement/Undo/<eXit>: X
    [Move/Copy/Rotate/Scale/Base/Undo]<eXit>: R
    Second Point or Rotation angle:
    i don't want to write C - X - R. I Want to click only one time and copy and rotate.
    is it possible??
    Thanks for your disponibility.
    Marco
    *Gordon Stephens
    05-24-2009 01:40 AM in reply to: Maark
    Here is a simple lisp routine that has no error checking, but it does the
    job, so make sure you load the lisp and if it has to be a macro, then call this
    lisp with the macro:
    (defun c:cir ()
      (setq ss (ssget ":smileyfrustrated:" '((0 . "INSERT")))) ;select
    a block
      (setq blk (entget (ssname ss 0))) ;retrieve block
    definition
      (setq bip (cdr (assoc 10 blk))) ;retrieve blocks insertion
    point
      (command "_copy" ss "" bip pause) ;copy the block once from it's
    insert point
      (setq ropt (getvar "lastpoint")) ;get the picked point
    for the insertion
      (command "_rotate" "last" "" ropt) ;rotate the
    copy around the insertion point
    Gordon
    i've wrote in the
    MACRO
    MENU:
    The
    problem
    point, it's
    original, not the
    copy.
    I'm sorry for my
    english...
    Thanks..
    Marco
