File Attachments
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Problem Macro Copy Rotate
Options
- Highlight
- Email to a Friend
141 Views, 3 Replies
04-24-2009 02:56 AM
Hi, i've a problem with using the macro menu.
I want take an object and its insert point. in the same point I should rotate the object without using the rotate command.
I want to create a command where i can copy, insert this, eand rotate an object.
i've wrote in the MACRO MENU:
^C^C_copy;\;_int;\;_rotate;
The
problem is that when i take the object, without define its insert
point, it's copied in to the screen, and a can rotate only the object
original, not the copy.
I'm sorry for my english...
Thanks..
Marco
The
Thanks..
Marco
Re: Problem Macro Copy Rotate
Options
- Highlight
- Email to a Friend
04-28-2009 04:30 AM in reply to:
Maark
type MOCORO
Options
- Highlight
- Email to a Friend
04-30-2009 07:50 AM in reply to:
Maark
is possible an automation for Mocor..
Initializing...
_MOCORO
Selezionare oggetti: trovato(i) 1
Base point:
[Move/Copy/Rotate/Scale/Base/Undo]<eXit>: C
Second point of displacement/Undo/<eXit>:
Second point of displacement/Undo/<eXit>: X
[Move/Copy/Rotate/Scale/Base/Undo]<eXit>: R
Second Point or Rotation angle:
i don't want to write C - X - R. I Want to click only one time and copy and rotate.
is it possible??
Thanks for your disponibility.
Marco
Initializing...
_MOCORO
Base point:
is it possible??
Marco
*Gordon Stephens
Options
- Highlight
- Email to a Friend
05-24-2009 01:40 AM in reply to:
Maark
Here is a simple lisp routine that has no error checking, but it does the
job, so make sure you load the lisp and if it has to be a macro, then call this
lisp with the macro:
(defun c:cir ()
(setq ss (ssget "
" '((0 . "INSERT")))) ;select
a block
(setq blk (entget (ssname ss 0))) ;retrieve block
definition
(setq bip (cdr (assoc 10 blk))) ;retrieve blocks insertion
point
(command "_copy" ss "" bip pause) ;copy the block once from it's
insert point
(setq ropt (getvar "lastpoint")) ;get the picked point
for the insertion
(command "_rotate" "last" "" ropt) ;rotate the
copy around the insertion point
(setq ss (ssget "
a block
definition
point
insert point
for the insertion
Gordon
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<Maark> wrote in messageHi,
href="news:6169553@discussion.autodesk.com">news:6169553@discussion.autodesk.com...
i've wrote in the
MACRO
MENU:
The
problem
point, it's
original, not the
copy.
I'm sorry for my
english...
Thanks..
Marco
