• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    File Attachments
    Member
    How can I see what drawings an xref is referenced into?
    117 Views, 2 Replies
    04-03-2009 01:00 PM
    How can I see what drawings an xref is referenced into? I would like to find out how many drawings/which drawings are referencing a particular file. Does anyone know how to get this information?
    Thx in advance!
    Please use plain text.
    *Laurie
    Re: How can I see what drawings an xref is referenced into?
    04-03-2009 03:43 PM in reply to: fpilson
    Hi frank,
    The XReffed file has no information on any files to which it may be
    referenced.
    Thus you have to examine ALL the other files to see if they use it.
    Laurie Comerford
    > file. Does anyone know how to get this information? Thx in advance!
    *Shoey
    04-06-2009 01:06 AM in reply to: fpilson
    Hi
    You can use the Design Centre Tool for this.
    In Design Centre, select the search tool.
    In the "look for" section, select Xrefs.
    In the "search for the name" section, enter name of your Xref (without the
    .dwg extension).
    Use the "Browse" button to select drives, directories.
    Use the "Search sub-folders" button as an option.
    Click "search now".
    A list of the drawings containing the named Xref dwg file will appear in the
    bottom pane.
    Cheers
    Mark
