• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    File Attachments
    *Spangler, John
    BUG? Leader Entites create hook lines when drawing gets bound - Suggestions w
    45 Views, 0 Replies
    06-17-2003 04:27 AM
    I am using ADT3.3 using the QLeader command without hook lines. If you list
    the Leader entity it says "Hook Line: OFF". When the drawing gets bound to
    another, Hook Lines on some leader entities mysteriously appear in random
    locations. After binding and exploding and you list the Leader entity it
    says: "Hook Line: ON". Please see the example drawing (zipped) uploaded
    to the FILES group under the same subject.
    Is this an AutoCad BUG? Any suggestions on a fix?
    Please use plain text.
