File Attachments
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Hughes, Chris
ADT4 Options and Settings
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
31 Views, 0 Replies
06-17-2003 12:18 AM
WARNING: this is not an Autodesk document and I make no claims that this
will work for everyone. Use at your own risk. These are the changes I make
to the default installation and I have not experienced any significant
problems, as yet. You may not want to move all folders onto a netwrok
location as I have, this is up to you. Also, I work in a metric
environment, so some changes are made specifically to get ADT to use metric
defaults - specifically the Tool Palette File Locations setting.
In all cases the following applies in this document. The network location
"I:\CADD\CADSTD\" is my base network directory. This would be different on
every server. Under this folder, I have essentially copied (moved actually)
the entire C:\Documents and Settings\All Users\Application
Data\Autodesk\Autodesk Architectural Desktop 2004\R16.0\enu\... directory
contents.
Good luck.
Chris
contents.
Good luck.
Chris
