We need more properties added to the assets
We must have the possibility to add more production information's to the assets. Then we can use them for simulation and optimization. Also this assets need to be used in the early stage of the process.
Workflow - define your stations include. all relevant properties - place them in your factory - do simulation/optimization - check locations of stations against the factory building - do optimization again.
Today the Process simulation has only icons - so no idea what it will be. If this process is final - you start again in ACA with the optimization (and you type in all the properties again).
Regards
Frank
5 Comments
mike_jolicoeur
How about this....  We allow a user to "assign" an asset from the library to a process block in PS 360...  we add the simulation information in PS 360...
and then the ability to save off process blocks that are already assigned to assets for re-use in other PS 360 simulations?
mike_jolicoeur
One other question....
You would want the PS 360 data to be viewable / accessable from the layout environment?
Would you want that from 2D or 3D?  Or both?
mike_jolicoeur
Hi Frank,  Would what we are proposing here make sense for the workflow?
mike_jolicoeur
XuesongBai
Status changed to: Gathering Support
