Suppression Property Should work with Level of Detail
Currently, if you use the feature property suppression option, (see attached) the suppression is not recognized when setting various levels of detail. I use this property for turning Clearance areas on and off. When there are multiple pieces of equipment that have these clearances, we use a Level of Detail to turn them all off or on as needed. Currently you have to actually suppress the part to add it to the Level of Detail in the assembly.
3 Comments
mike_jolicoeur
Currently, the only way this can be achieved is, as you have documented, through an assembly. If I am understanding correctly, you would like a concept of an LOD on a multi body part - that would allow you to suppress the features you want suppressed.... is that correct?
Light_Guy
That is correct sir! Would like to be able to hide a hole or extrusion as the need dictates.
XuesongBai
You can create the user view in multi-body part. So you can set  the bodies which need not to be on as invisible in the user view.
