4 Kudos
Point cloud insert workflows (scaling)
Status: New Idea
by Employee mike.jolicoeur on ‎10-17-2012 06:27 AM
Point clouds should know the scale of the document they are going into and attempt to scale accordingly.  Point clouds typically are meter by meter by meter for scaling size - if the point cloud goes into a layout that is in MM it should scale - or if it is into an inch layout it should scale to imperial - if nothing else, have it work similar to block inserts in AutoCAD for the interaction.  (see attached)  IT is very confusing for the users in imperial - typically the cloud comes in 254x too small.
Status: New Idea
Comments
by Employee mike.jolicoeur on ‎02-04-2013 08:24 AM
Status changed to: New Idea
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea
