Point cloud insert workflows (scaling)
Point clouds should know the scale of the document they are going into and attempt to scale accordingly.  Point clouds typically are meter by meter by meter for scaling size - if the point cloud goes into a layout that is in MM it should scale - or if it is into an inch layout it should scale to imperial - if nothing else, have it work similar to block inserts in AutoCAD for the interaction.  (see attached)  IT is very confusing for the users in imperial - typically the cloud comes in 254x too small.
2 Comments
Status changed to: Gathering Support
