Create Assets using Assets
We have discovered that while trying to make an asset, there is no way to use an existing asset in the creation of another. Assets should be accessible when creating assemblies not just when creating a factory layout. Many times we need to have assemblies that contain standard assets but we still need to be able to change those assets once they have been inserted. Right now you get an error that says that part contains a factory layout and cannot be used to make an asset. (see attached) This is because the only way to see the asset was to create a layout to insert it into.
10 Comments
mcmahor
So nested Asset creation, correct? how deep of nesting do you require? 2,3,4 levels? What if we put the ability to identify what assets were used to create an asset in metadata for a created asset? That way you could search for and find where an asset was used.
I assume your request means that if you update a sub-asset that you would like the parent assets to be updated?
Light_Guy
Correct, nested assets. I would say no deeper than 3 levels. Absolutely on the metadata! The biggest thing is that we would need to be able to still modify the parameters of all the assets while in the nested asset. (Example Sub1 has 3 variations, a,b and c. Sub2 has 4 variations, 1,2,3 and 4. Would like to be able to set Sub1 at B and Sub2 at 3 or any combo thereof while in the master asset.)
mcmahor
Got it! Thanks very much for the input!
mcmahor
Status changed to: Accepted
Light_Guy
Fantastic! Thank you for giving us the input opportunity!!
mk92
Any News regarding this idea?
Hope to see some News soon!
XuesongBai
XuesongBai
Your idea has been accepted and is being tracked in FDS-11781 and 11780.
liqinomickey
This Idea has been implemented in Autodesk Factory Design Utilities 2019 release. Function called "Insert Asset Group". Thanks to all who voted for this feature.
For more information please refer to help page.
