FMDesktop
Active Member
mistersq
Message 1 of 2 (121 Views)
Repetitive work orders
121 Views, 1 Replies
10-06-2006 10:02 AM
I have dozens of air handlers:
Does it make sense to create a different work order for each air handler for the same bi-yearly operation (coil cleaning), with FM software??
Member
smkcafm
Message 2 of 2 (121 Views)
Re: Repetitive work orders
10-06-2006 02:42 PM in reply to: mistersq
mistersq -
If all the air handlers will be serviced in the same cycle you could create one multi asset work request listing the air handlers to be serviced. This will create one work request with each equipment asset listed, it will have a check box next each to record.
If you will be setting the service cycle to have a different unit serviced on different days or weeks - then going with separate work request would be the best way.
Stephen Komisarek
FM Solutions Consultant
Building Solutions Division
www.autodesk.com
www.fmdesktop.com
You are not logged in.
Ask the Community
