FMDesktop (Read Only)
FMLINK-ERROR ON AUDIT
4 REPLIES 4
475 Views, 4 Replies
I receive the following error on AUDIT. Continue button allows return to FM LINK. Publish casuses ACAD to crash.
Any thoughts?
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: startIndex
at System.ParseNumbers.StringToLong(String s, Int32 radix, Int32 flags, Int32* currPos)
at System.Convert.ToInt64(String value, Int32 fromBase)
at Autodesk.Aec.Utility.Db.StringToHandle(String strHandle)
at FmLink.ObjectInfo.SetFromObject(DBObject obj)
at FmLink.Helper.Equipment.CollectEquipment(Database db)
at FmLink.Application.CommandClass.AuditBlocks(ObjectIdCollection& drawOrderIds)
at FmLink.Application.CommandClass.Audit()
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at AcMgCommandClass.InvokeWorker(AcMgCommandClass* , MethodInfo mi, Object commandObject, Boolean bLispFunction)
at AcMgPerDocumentCommandClass.Invoke(AcMgPerDocumentCommandClass* , gcroot<:REFLECTION::METHODINFO>* mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.TargetInvocationSEHExceptionFilter.InvokeWorker()
at Autodesk.AutoCAD.Runtime.ExceptionFilter.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///D:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.0.116.0
Win32 Version: 17.0.116.0
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///D:/WINNT/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd/msvcm80.dll
System
CodeBase: file:///D:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Xml
CodeBase: file:///D:/WINNT/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
CodeBase: file:///D:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Windows.Forms
CodeBase: file:///D:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
acmgd
Assembly Version: 17.0.54.0
Win32 Version: 17.0.54.0
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/acmgd.DLL
AecDtlDb50
Assembly Version: 5.0.318.0
Win32 Version: 5, 0, 318, 0
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AecDtlDb50.DLL
AecDtlDbUI
Win32 Version: 5.0.318.0
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AecDtlDbUI.DLL
AecDtlDbLib
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AecDtlDbLib.DLL
AcDxUi
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AcDxUi.DLL
AcDx
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AcDx.DLL
AcDxUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/en-US/AcDxUi.resources.DLL
AcMgdShared
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AcMgdShared.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/en-US/AcLayer.resources.DLL
FmLink
Assembly Version: 7.0.154.0
Win32 Version: 7.0.154.0
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/FMDesktop/FmLink.dll
AecUtils
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/FMDesktop/AecUtils.DLL
FmLink.resources
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/FMDesktop/en-US/FmLink.resources.DLL
acmgdinternal
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/acmgdinternal.DLL
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
CodeBase: file:///D:/WINNT/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
AecUtilsWrapper50
Win32 Version: 7, 0, 154, 0
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/FMDesktop/AecUtilsWrapper50.DLL
System.Data
CodeBase: file:///D:/WINNT/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///D:/WINNT/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///D:/WINNT/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Configuration
CodeBase: file:///D:/WINNT/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AecBaseMgd
CodeBase: file:///C:/Program%20Files/Autodesk%20Architectural%20Desktop%202007/AecBaseMgd.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
4 REPLIES 4
mark.evans
That's an exciting crash! This should be submitted to Product Support for resolution. I would cut and paste it to them, but it wouldn't do any good since I don't know who you are. Send a note to support@fmdesktop.com
Mark Evans
Product Manager, FM Solutions
Mark Evans
Senior Product Manager
AEC Division, Simulation Product Line
Autodesk, Inc.
Mark-
Yuppers....that was exciting. After a whole lot of head scratching and more than a few follicles on the floor, I rebuilt the database and the problem went away. PITA though.
I'll submit to Support, maybe they can figure it out. Product or OE? I'd like to know.
mark.evans
Product Support. I don't know what OE means...
Mark
Mark Evans
Autodesk, Inc.
mark.evans
Duuuhh... It took me a minute. You mean product error or operator error! Either way, it should be handled more gracefully than that!
Mark
Mark Evans
Autodesk, Inc.
