Hello all. I am having an issue with AutoCAD/Archibus connections correctly, so I thought I would post a message here and see if anyone had any advice.
Every time I use an Archibus command in AutoCAD (edit data, uncatalog), AutoCAD gets an fatal error....Unhandled e06d7363h Exception at 7c812afbh. I've found that this error can be linked to the .net framework. I currently have the correct .net framework, and I still keep getting the error. I'm thinking I am overlooking a setting or forgot a customized file somewhere.
Any ideas?
Thanks!
