Hi 🙂
just a message to say that I hope a vs2013 version of lib will be released soon 🙂
Thanks for the work you do
Hi
Support for VS2013 hasn’t been started yet. We do not expect to support it in the FBX 2014.x line, this will most likely come in a future release. However, you can still use the VS2013 IDE, setting the toolkit to the VS2012/VS2010 version. Doing this you can enjoy the VS2013 IDE new features and still use the compiler/linker from VS2012/VS2010 depending which one FBX requires.
you can download VS 2012 Express here :
http://www.microsoft.com/en-us/download/details.aspx?id=34673
Do you have any ETA on when users should see an FBX 2014 SDK support Visual Studio 2013 ?
We have already moved our entire project to VS2013 now ? VS2012 is no longer an option for us.
I would like to chime in as well... I personally find it highly annoying when a 3rd party closed source lib forces me to use an outdated compiler (specially when 2013 adds a bunch of C++11 features I think a lot of people were hoping to use). Granted this is mostly Microsoft's fault for making libs incompatible between VS versions so frequently. But still, one would expect/hope that you guys would prioritize adding new versions of VS to your build.
EDIT: With that said, a better temp workaround is to switch to the FBX DLL (FBXSDK_SHARED) which seems to work so far, although I only want to ship using the static lib so this only works for the near term.
Support for VS2013 is something we are currently doing and should be part of our next beta.
I got an email recently
FBX 2015.1 beta 1 is now available for download
Highlights of this release:
Hi
The FBX 2015.1 beta1 which includes VS2013 support was posted few days ago on the beta boards -
