FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
csv in python sdk
1 REPLY 1
malcriado3d
1048 Views, 1 Reply
csv in python sdk
Hi guys,
trying to figure out how to set keyframes in my script, lets say rot X , taking data from a csv row that has the time value and another row that has degree value. Any tips or ideas where i can look for?
thanks in advance!
Francisco Criado
1 REPLY 1
akira.kudo
in reply to: malcriado3d
A sample code "ExportScene01.py" below in the sdk would be helpful for you. As you can see it, there are also helpful comments what we have to do for creating animation.
Please see in detail a URL below.
http://docs.autodesk.com/FBX/2014/ENU/FBX-SDK-Documentation/index.html?url=files/GUID-E5C89F5F-09D1-...
<code_begin>
# Create two animation stacks.
def AnimateSkeleton(pSdkManager, pScene, pSkeletonRoot):
    lKeyIndex = 0
    lTime = FbxTime()
    lRoot = pSkeletonRoot
    lLimbNode1 = pSkeletonRoot.GetChild(0)
    # First animation stack.
    lAnimStackName = "Bend on 2 sides"
    lAnimStack = FbxAnimStack.Create(pScene, lAnimStackName)
    # The animation nodes can only exist on AnimLayers therefore it is mandatory to
    # add at least one AnimLayer to the AnimStack. And for the purpose of this example,
    # one layer is all we need.
    lAnimLayer = FbxAnimLayer.Create(pScene, "Base Layer")
    lAnimStack.AddMember(lAnimLayer)
    # Create the AnimCurve on the Rotation.Z channel
    lCurve = lRoot.LclRotation.GetCurve(lAnimLayer, "Z", True)
    if lCurve:
        lCurve.KeyModifyBegin()
        lTime.SetSecondDouble(0.0)
        lKeyIndex = lCurve.KeyAdd(lTime)[0]
        lCurve.KeySetValue(lKeyIndex, 0.0)
        lCurve.KeySetInterpolation(lKeyIndex, FbxAnimCurveDef.eInterpolationCubic)
        lTime.SetSecondDouble(1.0)
        lCurve.KeySetValue(lKeyIndex, 45.0)
        lTime.SetSecondDouble(2.0)
        lCurve.KeySetValue(lKeyIndex, -45.0)
        lTime.SetSecondDouble(3.0)
        lCurve.KeyModifyEnd()
    # Same thing for the next object
    lCurve = lLimbNode1.LclRotation.GetCurve(lAnimLayer, "Z", True)
    if lCurve:
        lCurve.KeySetValue(lKeyIndex, -90.0)
        lCurve.KeySetValue(lKeyIndex, 90.0)
    # Second animation stack.
    lAnimStackName = "Bend and turn around"
    # Create the AnimCurve on the Rotation.Y channel
    lCurve = lRoot.LclRotation.GetCurve(lAnimLayer, "Y", True)
    if lCurve:
        lCurve.KeySetValue(lKeyIndex, 720.0)
    if lCurve:
<code_end>
For reading csv, there are a lot of artcles in websites. So a URL for instance would be helpful.
http://www.pythonforbeginners.com/systems-programming/using-the-csv-module-in-python/
I hope this helps.
Akira Kudo
Developer Technical Services
Autodesk Developer Network
