Show only
Search instead for
no,i have tried it,but it didnt work!3DS MAX FBX PLUGIN cant export the near clip distance and aspect width and height are not the clip volume top,bottom,left,right!it just the viewport's properties~
Hi, there, I am confused what you want to do. Could you explain your expectec workflow? And do you want to use Plugin or SDK in your workflow? If you meet problem for the usage of Plugin, please ask on the plugins forum where you can get a better answer.
And I doubt what kind of camera did you export from 3ds Max? Is it an orthogonal projection camera?
