Area :: Header
Join us at EUE2014, June 5-6, Utrecht-NL
Register Now
Discussion Groups
FBX SDK
Scribe_1
Triangle Strip
103 Views, 3 Replies
12-12-2010 10:47 AM
Hi guys,
Is there any built in support for creating/identifying triangle strips?
Many thanks
Please use plain text.
keres
Re: Triangle Strip
12-12-2010 11:23 AM in reply to: Scribe_1
Are you talking about for DirectX or OpenGL? I've since figured from asking a question here that you should set the mapping mode on everything to eBY_POLYGON_VERTEX and run the imported mesh through your optimization algorithm, which will produce triangle indices. You will then be able to render a mesh as a series of index polygons.
Scribe_1
Re: Triangle Strip
12-15-2010 11:54 AM in reply to: keres
The issue I have here is that it's for some educational Nintendo DS homebrew, the system doesn't support vertex arrays.
Distinguished Contributor
Re: Triangle Strip
12-20-2010 10:16 PM in reply to: Scribe_1
Nop, there is no such function in FBX SDK yet.
