Are you talking about for DirectX or OpenGL? I've since figured from asking a question here that you should set the mapping mode on everything to eBY_POLYGON_VERTEX and run the imported mesh through your optimization algorithm, which will produce triangle indices. You will then be able to render a mesh as a series of index polygons.
