FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
Triangle Strip
3 REPLIES 3
1011 Views, 3 Replies
Triangle Strip
Hi guys,
Is there any built in support for creating/identifying triangle strips?
Many thanks
3 REPLIES 3
Are you talking about for DirectX or OpenGL? I've since figured from asking a question here that you should set the mapping mode on everything to eBY_POLYGON_VERTEX and run the imported mesh through your optimization algorithm, which will produce triangle indices. You will then be able to render a mesh as a series of index polygons.
The issue I have here is that it's for some educational Nintendo DS homebrew, the system doesn't support vertex arrays.
jiayang.xu
Nop, there is no such function in FBX SDK yet.
