Howdy,
OK, the ConvertScene example shows how to export the current version 7 and the older version 6, but it doesn't show how to export the in between versions: 7.0, 7.1, etc.
How can I export the in between versions?
Adios,
Cactus Dan
If you could find any solution for that, would you please share it with me ?
Unforunately file formats (like FBX 6.0 ascii (*.fbx) ) only works with 6.0, and other versions like 7.1, 7.2 etc .won't work.
Finally found the solution.
Use FindWriterIDByDescription for fileformat like ("FBX ascii (*.fbx)"), then call the following for setting version:
lExporter.SetFileExportVersion(FbxString("FBX201100"), FbxSceneRenamer::eNone) // or FbxSceneRenamer::eFBX_TO_FBX);
It is using version format by year, not numbers (7.1,...)
Note that fileformat of "FBX 6.0 ascii (*.fbx)" only supports 6.0 and no other version number, so don't call "FBX 7.1 ascii (*.fbx)"
