Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
FBX Plug-ins Import-Export Discussions
Active Member
patconnole
error output in script editor?
30 Views, 2 Replies
04-13-2012 05:23 PM
Is there a way to grab any errors that an export generates, within Maya? (instead of accessing the log file). Are they output to a string that can be easily accessed?
Error: Unsupported Operation on Mesh Vertices
The plug-in has detected mesh nodes with unsupported operators that affect the vertex and/or face count. To correct this, delete the Non-deformer history before exporting. The following nodes will not be processed:
pCube1
Thanks!
Please use plain text.
Distinguished Contributor
CarlosC_1
Re: error output in script editor?
04-18-2012 10:03 AM in reply to: patconnole
Hello patconnole,
Unfortunately, there is no mechanism to access them within Maya. They are logged to the file so your best bet is to parse this file.
Carlos
Active Member
patconnole
04-20-2012 02:33 PM in reply to: patconnole
Thanks for the response! I've decided to just wipe the file, export, then read its content with every export.
With python, I'm using this to find the log:
os.path.expanduser('~/maya/FBX/Logs/2012.1/maya2012exp.log')
