I'm currently importing an fbx from MotionBuilder to Max 2008 (via fbx 2006 - the latest compatible version). I don't have access to Motion Builder as I am only converting the data I am given. All things in the scene seem to be fine. However...the camera is not present at all. I've looked at the scene via the fbx viewer and both the source file and the converted fbx are fine. I've doubled checked to see the fbx import camera options are checked (and they are) but still no camera from this scene into Max. I suspect the problem is caused by cameraswitcher. Are there any other options that I need to check or change? Using FBX convertor 2012.2
Thank you.
Stuck in a timewarp with 3ds Max 2008
WinXP x32 (SP3)
i7 CPU, 950 @ 3.07GHz, 3.5Gb Ram, DX 9.0c
AMD Radeon HD 5500, Display Driver ver. 9.00.100
Coffee: Almost empty
