Area :: Header
3ds Max 2015 Extension 1 is here
With new tools to power your pipeline
Discussion Groups
FBX Plug-ins Import-Export Discussions
Active Contributor
eric
Maya2010 - FBX import "unrecognized file type"
1184 Views, 2 Replies
05-13-2010 08:11 AM
I downloaded the latest FBX plug-in, the correct version, installed it.
Open Maya, import, and FBX is an unrecognized file type. Is there a secret handshake I forgot?
Eric
Please use plain text.
Active Contributor
eric
Re: Maya2010 - FBX import "unrecognized file type"
05-13-2010 08:44 AM in reply to: eric
Found it: it was not enabled in the plug-in manager.
Seems this should be modified in the install of the FBX plug-in.
Active Contributor
Damon-QA
05-13-2010 01:19 PM in reply to: eric
Hi Eric !....
I will look into this and try to get some info to you as soon as I can.
- Damon
