Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
FBX Plug-ins Import-Export Discussions
Active Member
sachin joshi
Maya camera film offset
142 Views, 5 Replies
05-19-2010 10:16 PM
We are doing a stereoscopic project inside maya, but our fx department doing all the fx in max.
Our stereoscopic department have made the camera with the shift in film offset in x axis.
They used camera film offset under camera attribute rollout.
But when we import it to max, they dont align properly, why? Is the camera film offset function not supported or is there any way around.
Thankyou
Sachin
Please use plain text.
Distinguished Contributor
Numerator
Re: Maya camera film offset
05-22-2010 07:10 PM in reply to: sachin joshi
Are you making sure the units are the same?
Active Member
sachin joshi
05-31-2010 10:09 PM in reply to: sachin joshi
yes the units are same,
the problem is that the right camera have the film offset value of -4, which max dont recognize. but the left camera dont have any offset value. i.e they are set to 0,0 in each axis. so no problem for left camera. but right camera dont match up.
adamst
08-02-2010 02:23 PM in reply to: sachin joshi
You're right: Maya's Film Offset values are not exported to FBX and therefore are not importing into 3ds Max. I've attached a spreadsheet we use internally as reference for Camera interop between Maya and FBX, along with the importing into other applications like 3ds Max.
Let me know if you need more information.
Thanks.
camerainterop.zip
-Trevor
New Member
rupeshvpatil
04-09-2012 03:45 AM in reply to: sachin joshi
same issue i am also facing, for importing a stereo camera from maya to max , it's giving film offset error warning.. please tell me the solution....
Thankyou
rupesh patil
CarlosC_1
04-10-2012 06:59 AM in reply to: rupeshvpatil
Hello rupshvpatil!
Unfortunately, there isn't anything we can do since it is a limitation of the plug-in. Perhaps this limitation will be addressed in a future release, but for now there are no immediate plans to fix it.
Perhaps there is a way to correct the offset with a script at the time of import. Once you find the proper values in Max, you could may be able to extrapolate them for any future imports. I cannot say that this is a solution, it is only a suggestion.
Best of luck,
Carlos
