FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
Maya camera film offset
5 REPLIES 5
2530 Views, 5 Replies
We are doing a stereoscopic project inside maya, but our fx department doing all the fx in max.
Our stereoscopic department have made the camera with the shift in film offset in x axis.
They used camera film offset under camera attribute rollout.
But when we import it to max, they dont align properly, why? Is the camera film offset function not supported or is there any way around.
Thankyou
Sachin
5 REPLIES 5
Are you making sure the units are the same?
yes the units are same,
the problem is that the right camera have the film offset value of -4, which max dont recognize. but the left camera dont have any offset value. i.e they are set to 0,0 in each axis. so no problem for left camera. but right camera dont match up.
trevor.adams
You're right: Maya's Film Offset values are not exported to FBX and therefore are not importing into 3ds Max. I've attached a spreadsheet we use internally as reference for Camera interop between Maya and FBX, along with the importing into other applications like 3ds Max.
Let me know if you need more information.
Thanks.
camerainterop.zip
Trevor Adams
Maya Design Team Manager, Mudbox Designer, Maya Modeling Designer
Twitter | LinkedIn
same issue i am also facing, for importing a stereo camera from maya to max , it's giving film offset error warning.. please tell me the solution....
Thankyou
rupesh patil
Hello rupshvpatil!
Unfortunately, there isn't anything we can do since it is a limitation of the plug-in. Perhaps this limitation will be addressed in a future release, but for now there are no immediate plans to fix it.
Perhaps there is a way to correct the offset with a script at the time of import. Once you find the proper values in Max, you could may be able to extrapolate them for any future imports. I cannot say that this is a solution, it is only a suggestion.
Best of luck,
Carlos
