• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • FAQ & How To: Using Autodesk Discussion Groups
    Administrator
    wrighte
    Kudos! (New April 18)
    4023 Views, 0 Replies
    04-18-2011 08:56 AM
    Find a post helpful?  Appreciate insights from a particular user?
    Now you can recognize/share your appreciation by giving the post a Kudo (thumbs up).  To give a Kudo, just click on the thumb icon on the post you want to recognize.  You can only give one Kudo per post, but total Kudos given is also displayed (note you can’t give yourself a Kudo).  Simple!
    Kudos give you insight into content and contributors the community finds valuable.
    There are a several settings you can configure.  Check them out under the Kudos tab in My Settings.
    What about the "Accept as a Solution" button?
    This is only used when you find a post or several posts directly answer your question.  If you have searched the forums, you know this provides great value in finding an answer more quickly.  You could also give the person/post a Kudo if you wish, but Kudos also allows you to recognize someone being helpful or providing insight even if not the direct answer.
    Enjoy!
    Eric Wright
    Sr. Web Product Manager
    Autodesk Knowledge Network
    Please use plain text.
