Discussion Groups
Everything Else: General Discussion
Board Manager
colin.smith
Contact Case Project
426 Views, 1 Replies
04-05-2013 01:13 PM
I recently received an Umbra contact lenses case as a gift and I thought it would make a good project to do in Fusion 360.  The base of the contact case is a perfect job for the T-Splines sculpt tools and the rest of the model is an easy task for the solid modeling tools.
I found an image of 80s style sunglasses and used that as a background to create the frames.  If you are using a background image it is a good idea to calibrate the image to the correct size of the object you want to build so that you are working in the correct scale.
Right click background image in your canvas folder and select Calibrate from the dropdown menu. I set the distance between the outer edges of the frames to 9.5 cm to match the actual model.
I used Sculpt > Create > Create face to outline the shape of one side of the frames in flat faces and then used the sculpt extrude tool to extrude both sides of the faces with symmetry.
Next I deleted the faces where the bridge of the frame will be.  When doing this make sure you pick the faces and delete, if you pick the edges you may remove more faces than you intended.  Symmetry > Mirror Duplicate was used to make a copy across the center line of the frames.
To connect the two sides I used Bridge.
I wanted to make further modifications to the frames so I put symmetry across the object center line so that any adjustments made to one half would be reflected on the other.
Once I had the frames the way I wanted I converted the T-Spline body to a solid body using the convert tool.
I created the lenses by sketching the shape, extruding to the right size and then combining the lenses with the frame.
The cup and cap were created in the solid tools. This project gave me a chance to try the new coil tool to make the threads on the cups.
I used the recently added coil tool to create the thread on the cup.
I created the letters for the caps by creating large letters in Microsoft Word, doing a screen grab and brining the images in a background planes. I then outlined the approximate shape using the spline sketch tools.
The cups were combined with the sunglasses base so that they were one object.
Lastly I made multiple copies and assigned different materials for a color study.
Total modeling time was about 6 hours over several days.
Colin Smith
Product Manager - Fusion 360
Please use plain text.
Board Manager
kat.ingalls
Re: Contact Case Project
04-05-2013 06:57 PM in reply to: colin.smith
Colin, this is incredible! You should definitely share this via the gallery-!!
http://fusion360.autodesk.com/gallery
Kat
Fusion 360 Social & Community Manager
twitter: @adskFusion360
facebook: /fusion360
