Ecotect Analysis Forum (Read Only)
shadows problems when importing dxf file
3 REPLIES 3
RobinCris
775 Views, 3 Replies
Hello all
When I import a dxf file to ecotect some of the shadows do not show.
When I look at the shadows in 3D editor, everything is great but when I move to visualize view, not all the elements drop shadow.
Did anyone encounter in that problem?
I use ecotect 2010.
3 REPLIES 3
Try checking the object shadow flag in the selection information... I need to see the file to help you..
Best regards Asbjørn
in reply to: RobinCris
Have you tried resetting the camera?? fromthe DEFAULT tab
 I also have the same problem with imported DXF files.
 Is there a solution?
 Thanks!
