Ecotect
Member
sixtydegree
Message 1 of 3 (541 Views)
import problem
541 Views, 2 Replies
06-19-2013 02:36 AM
I am trying to import a dxf format file to ecotect. it is a 2d drawing with simple lines. when i imported this file to ecotect, it said "Error: Selected model file does not match the selected data format or is corrupt."
why does it say that when the file formate is correct as far as i can tell. its not even a complex drawing ... it clearly has fewer than few lines. that is all. What could be the problem. I am new to ecotect although I have done tons of work when I imported the last drawing. No such problem was encountered. Now I dont know what to do and I can not move forward because I can not even import the file. Please can anybody help me out??
Active Member
sburke
Message 2 of 3 (531 Views)
Re: import problem
06-19-2013 06:52 PM in reply to: sixtydegree
I think you need to ensure the DXF format is v2000 or older. Are you creating the DXF from an Autodesk application?
Member
sixtydegree
Message 3 of 3 (509 Views)
Re: import problem
06-23-2013 02:19 AM in reply to: sixtydegree
the .dxf file that i tried to import is of 2007 version ... I tried by converting the file from 2007 to 2004 version as well.. the ecotect that i am using is of 2011 ... so what could have been the problem?? please help
You are not logged in.
Announcements
Ask the Community
