Ecotect Analysis Forum (Read Only)
building orientation effects on the overall heating and cooling loads
1 REPLY 1
115alialiali
620 Views, 1 Reply
Hi all,
I am using Ecotect 2011 to study how building orientation effects on the overall heating and cooling loads. My concern is when I change the building orientation, such as from East-West to North-south (90 degree), The results seem not realistic , the difference about 2.5%why is this? where I should look to find why?May Ecotect not the right tool for this kind of study?
Note the building has aspect ratio of 1:3.
best,
Mohamed
1 REPLY 1
Hi Ecotect is really using a pretty good dynamic simulation for calculating heating and cooling loads. But its really the effect not the loads for ventilation systems.. because its the pasiv loads its really a lot about the window areas and placement. so I think need to know a bit more about the model that you are testing. In my appnion Ecotect is preatty reliable...
Cheers
Asbjørn
