From Revit... sort of. gbXML out from Revit will export the entire model, and the selected phase. Potentially, you could alter the phase of the items you want to export, but it would be very messy.
Within Ecotect, you can switch to a front or side view, and hide the zones that you do not wish to work with.
- Press F6, or F7 to view the model from the front or side
- Select the zones and items you wish to hide or isolate
- RIght click and choose
Zone >
Isolate Selected Zone(s), or
Hide Selected Zone(s)
Your best bet for some activities is to simplify the model by representing only what is relevant to the task at hand. You can do this with DXF export within Revit of the plan view of the floor you wish to analyze and purpose build what you need to look at in Ecotect, tracing over the exported vectors to create your zones, shading devices (if any) and glazing. Bear in mind, this may not even need to be the entire floor, depending on what questions you need answered about the design. This will also have the advantage of clean and fast results for processing various analyses.
Sean D Burke,
Assoc AIA, LEED AP
sdb consulting
BIM, CAD and Sustainable solutions training and implementation
Read my blog ->
Paradigm shift
